Evinrude/Johnson charging
JasB
28 Oct 2005
Harwich
I have a 6hp evinrude/Johnson mix (handy with my hands) which has a charging socket on the side. Apart from the cable and male socket, what is required to charge my battery from this? Is it a direct connection, or is it via some sort of relay?
You don't say what year or what the model number is for me to check out the details but AFAIK that is an AC lighting supply. (3 pin ? , 2 pin ? )
Assuming that is the case then a charging lead and rectifier is available as an accessory.
Some were fitted with rectifier but then had a battery connection lead rather than a socket. My 6 HP Yachtwin is like that but for the standard version this shows the battery charging accessory.
http://12.2.215.22/Scripts/ImgServ.exe/c...IF=G&ilRE=8
As sure as eggs are eggs someone will tell you that all you need is a rectifier from Maplin. Unfortunately although that may be true for somemodels with only a two wire output from the stator others with the three pin plug require a 3 phase rectifier.
Tell me the year or preferably the model number and I will look up more details for you.
If your have the knowledge then you could build yourself a 3 phase rectifier.
Lakesailor types faster but I don't think he is right. As he says you can check with a multimeter but if it is a 3 pin socket i am sure you will find it is AC
The rectifier if fitted is likely to look like part #43 in this diagram.
http://12.2.215.22/scripts/EmpartISAPI.d...EG=0&ilGM=0
And be bolted to the side of the block (three yellow wires and a red wire.
Tell us the year and or model number!
Good point. If there is something that looks like this on the motor inside the cover, you have a regulator. (Or maybe with 4 wires)
If not contact these people http://www.mareng.co.uk/ who are incredibly helpful and will be able to provide what you need. All to the correct spec, but not at Johnson prices.
[/ QUOTE ] That looks like a very modern type where they have gone back to a single phase design again!
Need the age or model number!
Model number should be on a plate on the transom bracket. Sometimes it's also on a core plug on the engine.
Explanation of the model numbers HERE
My old Johnson 6 (about 1985 model has 2 lighting coils and 3 wires out. If you follow the wiring from the inside of the socket you will see it goes straight under the flywheel to the coils.
I don't think the coils are 3 phase but are out of phase.
i connected up a bridge rectifier and battery with amp meter. Crude I know but I connected the rectifier to the wires that gave the most current. It gives about 1/3 amp at normal sort of revs. So not much.
I think the coils ended up in series.
The problem is that it is a lighting coil designed to give an AC voltage that won't blow the small globes of a nav light system. For battery charging you need a lot more voltage to get any real current into the battery.
I never got around to trying them but Schotky diodes in a bridge connection should give a little more current. In a bridge rectifier there are 2 diodes in series for each polarty of AC cycle so 1.4 volts aprox. is lost whereas schotky diodes should get this down to about .3v for each diode.
A bridge recifier is often drawn is a diagram as a diamond shape of 4 rectifiers. 2 anodes are connected together to give -ve output and 2 cathodes are connected together to give +ve output. One AC wire goes to a anode and cathode connected together and the other AC wire goes to the other anode and cathode connected together.
Since making up the rectifier lead I have not used the motor on the boat so haven't used it in anger but it would be useful for someone who uses a motor a lot. Certainly no regulator needed unless you are using the smallest of SLA batteries like about 5AH. olewill
