Eva foam teak
john-m
13 Mar 2010
Looking to fit some of this on my boat decks. I've got a few questions for people who already have it.
Is the glue on the back of it good enough to stick it down or does it require something else, also how water proof and uv resistant is it?
Thanks john
KDee
4 Aug 2016
Cumbria
I would go with additional adhesive. Fitted 2 small pieces last year, one on step from bathing platform to cockpit, always exposed to weather. This has stuck well, looks ok, so far, and does the job, but is small enough to replace easily if necessary. Second one just inside cockpit, somewhat bigger. This has stuck well enough apart from one corner, which means I probably didn’t do a good enough job of cleaning the grp! The material seems to have good stability, is comfortable to walk on, easy to clean.
bigwow
26 Feb 2006
That's good to know, I'm thinking of doing the galley sole with it, a cheap one from Banggood, China.
fdisk
1 Mar 2010
I've used it both outside around the companionway and to overlay the badly worn cabin sole. Have had no issues with quality of the adhesive, it was easy to cut and fit, and is holding up well.
wellf100
5 Apr 2012
Guernsey
i ordered 2 rolls on ebay for about £100 total to put on all the non-skids parts of my boat (17ft open bow and exposed to the elements). I gave the non-skid a very light sand to flatten it slightly and stuck the decking on top with just the adhesive backing supplied on the EVA. Been down a year and still stuck firm after a year of use and weather. (I sealed round the edges to stop water getting underneath through the remaining non-skid pattern).
Very pleased with it and it has transformed the look of the boat and the feel underfoot for very modest cost.
Bouba
6 Sep 2016
SoF
Does anyone know if this Eva foam teak has any sound proofing or anti vibration properties? My engine is mid cabin and I was thinking about carpet but this looks a better option.
Final question, can you get the teak pattern to go around floor obstacles (like hatches) so it looks like real teak and not linoleum?
FlyingGoose
12 Feb 2019
The Known Universe
Hi no its just foam underlay and gives some insulation but not as good as using the noise cancelling flooring and you would need to cut out the hatches and line up the lines of the teak run , so it would be better to order extra.
I have laid all this down in my interior and have many hatches to cover , looks good when down , easy to clean and gives some insulation for heat
Bouba
6 Sep 2016
SoF
Thanks FG
