mhouse
Hi.
Each winter the stainless P bracket of my Dehler shows erosion to the flat side of the P bracket.
. The Bracket is not connectet to anything internally and the cutlass bearing is phenolic . The shaft anode erodes a fair bit each year . I do use mains power with a galvanic isolator but I unplug when the boat is left . A solar panel is left charging the batterys.
Any ideas how to stop this other than bolt an anode onto the bracket. I do hang an anode over the side when moored which is disolving fast this year so much so that the 8mm stainless wire eroded and parted.
