scottnewcombe
Ok So I've successfully removed the rotting transom from my 27' motorboat. The remaining framework is now cleaned back ready to receive the new ply. Cheque book in hand I am about to go off and buy ply, fixings and epoxy pack when someone at the club says "Oh I suppose you're putting that back with sikaflex then?". Hadn't thought of that?
I was planning on coating the ply with epoxy all round before fixing it. Then bonding it to the framework with epoxy (and silicon bronze screws)and then sheathing the outside with fabric afterwards. I have written to Wests who are sending an info pack etc.
Any thoughts on the where's and whyfores of each?? If sikaflex should it be a special type, does it need a primer, will it stick OK to the epoxied ply??
I need to get the transom on quick because the gybes from other club members are unbearable. "Aren't those deck drains a little big" "Turning her into a jet ski then?" "I take it you're not putting her into the water tomorrow then?" very funny I'm sure.
Cheers
Scott
Cheers
Scott
