Epoxy Filler
Poignard
23 Jul 2005
South London
I'm still not entirely clear what the OP wants advice on.
If it is fairing dents etc. in a bolted-on lead or iron keel, then epoxy with an easily sandable filler such as micro-balloons is what I would use.
If it is for the joint between a bollted-on keel and the hull, where flexibility is required, then I would use CT1.
Birdseye
9 Mar 2003
s e wales
Hi Ceirwang
Fairing in a Dehler 36 keel to hull it has always been done with Sikaflex but the finish has never been achieved even when wet and dry sanding, using all recommend grades. As to the amount of movement this is up for debate.
I was intrigued to see on my Starlight that Bowman had faired just the joint by using a rubber sealant, handled in such a way that the result tooked like a 1mm thick 20 mm wider rubber band all the way round the joint. Certainly worked well and I cannot believe that it would make any measureable difference to boat speed since it was smooth surface and had almost no cross sectional area forwards.
Cowie
18 Nov 2020
Sounds good its always a pain area
Cowie
18 Nov 2020
Why do you want it to remain flexible around the keel. Is it a Bavaria?
Absolutely not a Bavaria, am sure they are a good boat but not my weapon of choice for offshore racing, raced the match versions.
There's no flex more than is normal, the only reason for changing product. I am a believer of always look to improve
Cowie
18 Nov 2020
Hi Ceirwang
I have been using Sikaflex and your correct the finish has never been great. This is part of the reason I was going to try something diffent after 15years , Like all boats there is a small amount of flex due to the matirals and appendages.
westernman
23 Sep 2008
Costa Brava
Wouldn't polyester be better than epoxy for this kind of application?
Neeves
20 Nov 2011
Sydney, Australia.
A bizarre thread.
If the intent is to reduce the development of a hair line crack as such a development would impact performance during racing I might have thought the impact of the crack on performance would not be measured (though the movement of the keel/hull joint might have more impact). I'm unaware, I need to get out more, of any epoxy offering flex in the application described (no matter what the filler) and CT1 or a Sika is commonly the sealer/filler of choice for hull/keel joints.
Minimising the size of the joint by applying epoxy to the hull, laying a peel membrane and then attaching the keel, setting off and then re-sealing (as described earlier) so as to minimise the joint size seems a much more fruitful route.
Jonathan
Cowie
18 Nov 2020
Was only a question, in general thankfully boats back in the water. I plan to lift it out in 4 weeks or less. So we'll see if there's a issuse. If so the filler will be removed and be replaced by sikaflex.
There is a 7 day window before we return to the water .
