dah
Active Member
I have a Centaur fitted with an MD11c (Sea Water cooled). In this month's ST there is an article on winterization which states;
1. With a raw water system drain it and then flush it through with a mixture of freshwater and antifreeze. Once that is done REMOVE THE IMPELLER as the fins will set in curves if left over the winter. This is what I have always done.
However, I have just purchased Pat Manley's "Diesel Companion" which offers the following advice; flush the system through with fresh water and when the water in the bucket reduces to about 25% add the antifreeze. As the bucket empties stop the engine and do not restart until recommisioned.DO NOT REMOVE THE IMPELLER UNTIL RECOMISSIONING 0OR YOU MAY LOSE SOME OF THE WATER/ANTIFREEZE MIX.
Being not very technically efficent (thats an understatement), do I leave the impeller in situ or remove for the winter? Any thoughts/comments would be most welcome and appreciated.
