vas
good evening,
was about to ask that last year but forgot, now that I saw Piers thread on multicharging I thought I might as well send mine too
So, charging system seems to work fine with a Victron charger and engine alternators. I very rarely turn the engines when on the dock on shore power simply because I don't have shore power except in v.few occasions.
My problem is with the engine alternators themselves and not in relation to the Victron. Bear with me.
So, cruising at 1300-1500rpm 7-8kn at the beginning the VDOs on the dash show 24V then go to 28V and then zoom to over 32V
Initially I was scared looking at them up there, but after checking that batteries (open LA) were fine, levels were fine, I got used to it.
Now, once charged (I guess) they flick from 29V to 33V+ and then back again (say every few mins) and goes on and on for ever.
For the record, port engine does the service bank so hard work and always in need of some charge, whereas stbrd does bugger all, well starter batteries so often is more towards the 34V.
Throughout that time, the el. panel Voltometer (nice old one with a lovely needle) shows a fairly steady 28 (or thereabouts) which is as much as I see when the engine is off and the Victron is working (either via shore power or genny). Drops to 24 or even less after half a day on anchor, should improve with 600W of solar panels on the HT.
So, should I worry, should I have a look at the alternators, or forget it and get on with life? Anyone can relate these stages to float/charge or whatever my IVECO engines stock alternators can do?
following three pics show what I'm talking about, sorry too many light reflections but that's the only pics I found after a quick look
cheers
V.
cheers
V.
