Johnny WAFI
Hi all
After a very expensive rebuild to my Bukh 20, at the bottom of the bill was £65 to test run engine on relaunch (no problem) AND £165 for a river trial. At my request the £165 was broken down to £65 for the engineer (no problem) and £100 for his father's time on board. (The engineer's father owns the yard). I accept that a river trial was prudent to quickly check for shaft vibration and performance under power. But surely any other check could been carried out with the boat tied up? Am I being cynical in suspecting I am be charged for a father and son pleasure trip? If I knew this was going to happen I would have taken the engineer out on the river myself.
A few days later the new fuel tank tap failed contaminating my mooring lines (in the cockpit locker) and the sound proofing foam in the engine compartment with diesel. (The connector was loose but could not be tightened). I spent an hour mopping up and half a day each way motoring from my berth to and from the yard for a repair. My concern is that although diesel does not ignite easily, that the contaminated foam is a potential fore risk.
I would welcome advice on what request I should make to the yard.
Regards
Johnny
Regards
Johnny
