savageseadog
I recently saw someone jump starting his car with the aid of a Makita tool battery. No doubt other makes would work.
That sounds good.I recently saw someone jump starting his car with the aid of a Makita tool battery. No doubt other makes would work.
Had to do that when collecting a boat that got marooned by lockdown. 1GM10 and there was a sniff of rptten eggs about the battery. When we arrived at La Rochelle, just managed to do it again, but only just.Those car starter things won't usually work unless there are between 11 and 12 volts on the battery; they're meant to supplement a low battery, not replace a dead one. If a car starter would work, there's another trick that works very well for engines with a decompressor. Operate the decompressor and get the engine turning over with the starter. Because there's no compression, it will turn quickly even with a low battery. Then drop the compressor while the engine is turning quickly, and the engine will be turning fast enough to start. Had to do that once on mine; it works a treat. Of course, that won't work if the battery is completely an ex-battery, one that is no longer with us, but it will work if the battery will turn the engine, but not fast enough to start it.
I've never been able to start any diesel using decompression levers.That's fine as long as the solenoid relay actions on a low battery. Some fail to close on a low battery .....
On Decomp levers ..... my 4-107 and its previous 4-99 I had - no decomp lever ....
I've never been able to start a diesel using decompression levers. I had a Volvo 2000 series engine that came with a starting handle but I could never generate enough speed. I remember a diesel club launch that did not require a battery to start it. It had cranks and a bicycle chain affair. Worked well.
The NOCO GB40 I have has a button on it that bypasses the minimum voltage check so it will work with a dead flat batteryThose car starter things won't usually work unless there are between 11 and 12 volts on the battery; they're meant to supplement a low battery, not replace a dead one. If a car starter would work, there's another trick that works very well for engines with a decompressor. Operate the decompressor and get the engine turning over with the starter. Because there's no compression, it will turn quickly even with a low battery. Then drop the compressor while the engine is turning quickly, and the engine will be turning fast enough to start. Had to do that once on mine; it works a treat. Of course, that won't work if the battery is completely an ex-battery, one that is no longer with us, but it will work if the battery will turn the engine, but not fast enough to start it.
Don't you believe it!It is one thing turning with grips, another fast enough to get over a compression to fire. I had a 4-108.
I agree that starting a 200x series engine manually would be difficult for anything less than a gorilla; no flywheel so no way to store energy! But we regularly hand started an 8hp Sabb diesel, and I suspect that the technique that worked on that would work on other engines that have a large flywheel. Basically, you opened the decompressor, turned the engine with the crank handle as fast as you could to get the flywheel turning fast and then closed the decompressor. The flywheel would then take it through a couple of compression strokes, which was usually enough to get it started. I don't see why that technique wouldn't work with a bigger engine; the person cranking isn't trying to get it over TDC, it's the stored energy in the flywheel that does that.I've never been able to start any diesel using decompression levers.
I had a Volvo 2000 series engine that came with a starting handle but I could never generate enough speed. I later learned that the starting handle was never intended to start the engine.
I remember a diesel club launch that did not require a battery to start it. It had cranks and a bicycle chain affair and used hand an arm power . Worked well.
A standard car booster won't be enough to turn a higher compression deisel engine but if you buy a heavy duty boster it will work. I have had this one a couple of years SUAOKI E15 1500A Peak 2000mAh Jump Starter (for ALL Gas or 6.5L Diesel Engines) Portable Car Battery Booster with Type-C & USB 3.0 Quick Charge, Smart Clamps, LED Flashlight : Amazon.co.uk: Automotive and great peace of mind. Yes it has started cars and boat engines (Yanmar 240HP)
