Engine Room Ventilation.
Momac
7 Feb 2008
UK
27m3 per minute might seem like a lot but I am not sure it is in practice.
eg That's about a dozen air changes per minute for a 2m3 engine bay.
A 5 inch 4 amp 12V bilge blower fan could move 6m3 per minute . But why should the fan be required when the engine is itself a good air pump?
PaulRainbow
16 May 2016
Suffolk
Does your estimate allow for only filling the cylinders on every other stroke - assuming 4 stroke?
It doesn't John.
"estimating the engine will need 6 liters to fill the cylinders, 3000 times per minute, you get the result 18.000 litres"
Should only be 9,000 litres per minute.
EDIT, that's for non turbo diesel
penberth3
9 Jun 2017
It doesn't John.
Thanks Paul, my mental arithmetic gave me 9000 litres/min, but I wasn't sure!
And that is per minute, not per litre of diesel which was quoted in Post #15.
ss2016
24 Jul 2016
Looked at a different way. I think the numbers following are correct, and if so you are underestimating. Happy to stand corrected.
My understanding is to burn a litre of fuel you need in practice about 9000 lit of air.
At WOT your engine burns (??????) 1.4lit/min, so that is 12600lit/min.
You have 2 engines so about 25000lit./min.
And a different point you do not want to introduce a second resistance to the incoming air, and at that stage its less dense. So if 2 *575hp is what you want its perhaps time to adjust the furniture!
