spannerman
Having read the above advice and guess you have checked the obvious, carbs adjusted correctly and opening fully, diagphragms OK.
Have you changed the condensor and points, could be worth a look. And as mentioned check the advance mechanism too. But my feeling is that the cam timing has jumped a tooth or two. Dead easy to check, there is a notch on the rear cambelt guidewasher on the crank, line it up with the small mark on the timing belt cover. (check No 1 is at TDC by looking at the rotor arm position, should be near No1 plug lead on the distributor cap) then if you look on the back side of the camshaft pulley you will see a notch which should line up with a mark on the front end of the cam cover if I remember correctly, although some engines lined up to the top surface of the cylinder head at either 3 o'clock or 9 o'clock. The best thing is to take off the cam cover and check the two lobes on No1 cam are both pointing upwards equally, any marks a very obvious on these motors, if it has jumped just slacken the tensioner and realign the belt, its worth considering changing it if it has jumped as it means its probably stretched, check the tensioner bearing too. These engines suffer from rusting on the cam drive pulleys so give it all the once over, you will have to remove the heat exchanger but its dead easy after that.
Good luck and definitely go after your £2k, sounds like he shouldn't be near anything more complicated than a can opener!
