Stu Jackson
Check the fuse and fuseholder between the start button or key and the starter solenoid.
. . . What terminals do I bridge to both get motor running and engaged?
All this help is much appreciated.
ok if the motor turns but the solenoid doesnt kick the pinion in to engagement, it points to the solenoid sticking, the piston isnt moving or the coil has burned out (highly unlikely if it was working a few days ago)Curious & curiouser.... Cleaned the battery terminals with no difference. Have also tried bridging the terminals on the starter. There is a motor which kicks in but not turning over the engine.
Does the starter have two motors in it? There is no play in the stater motor mounting so I can't see how it's not engaging with the engine itself.
You'll be very lucky to start the engine with what is effectively a flat battery. It won't spin the engine fast enough to engage the starter pinion.My gut feeling is that my charger at home never fully charged the battery as its only showing 12v on the multimeter. I have today reinstalled the solar panel amongst other wee jobs.
It is a pre-engage type of starter. With those its the solenoid that engages the pinion. It's only inertia types that rely on the spinning motor to engage the pinion.It won't spin the engine fast enough to engage the starter pinion.
