Rhylsailer99
My bukh engine fitted to a cobra 850 i noticed the 2 front mounts loose so tried to tighten the nut and it just spins, im guessing a water pump leak as dripped water over many years into the mount area.
i went to drill them out to pour epoxy in as a quick fix for now but on one side the drill bit snapped inside ouch .
I think this winter i will have to remove the flywheel to get access and another big job broke out. the mounts look like they been bodged before as both have an extra bolt screwed in the front so 3 bolts total for each of the front mounts.
