Portofino
@petem + Bruce
From my post # 10
“Assuming normal manufacturing timed schedules you can prematurely loose power by overloading them which results in soaring EGTs .
The problem with sustained elevated EGTs is the exhaust valve mushroom .It’s insidious, it’s not a Big Bang scuse the pun .
They gradually loose best seating from a hermetic pov and pressure in the cylinder thus power gradually reduces as time and continuous overloading goes on .”
Which part of insidious do you not understand ?
For ease I have copied a typical google meaning below .
“ having a gradual and cumulative effect : developing so gradually as to be well established before becoming apparent “
@bruce where did you on all the posts thus far get this impression from you posted in your post #18 ?
quote Bruce “Your EGT doomsday placard doesn't bother me too much either to be honest. I am in the camp that you'd really have to abuse the boat to develop a problem there. Nobody is going to fit an engine into a boat that is not fit for purpose. That is not to say EGT is a concern, it's just not a Damocles sword. I do not fear my engine exploding......../........”
Curious to know seeing as I said it’s “not a Big Bang “ in my post #10 .
Which post / person are you referring to suggesting some sort of explosion ?
Mushrooming of exhausts valves due to prolonged excessive EGTs is well recognised insidious reason for marine diesels apparently loosing Hp as time goes by . Certain HGV drivers fit EGT sensors too .Helps them select the best gear climbing hills loaded up .Owner operators......you know the buck stops etc .
Fouling +excess weight are the instigators .Far away from the MBY test scenarios they regularly publish which are new ish demo boats with shiny bottoms + props with partial loads and almost zero cruising stores and years of collected accoutrements so many boaters end up with .That explains your manufacturer’s and journos articles .
From my post # 10
