engine hours
chrisumts
20 Jul 2007
Hi Everyone,
Can anyone give a 'rule of thumb' guide regarding engine hours on second hand boats please..? For example, I am looking at a Bayliner, (1995) which has 400 hrs engine use. (price EUR 26,000 ). Due to my inexperience, is this about normal for a boat of this age, and would this be a fair price ?
Many thanks in advance,
Chris.
jhr
26 Nov 2002
Royston Vasey
jamesrichardsonconsultants.co.uk
As a very rough rule of thumb, I'd say somewhere between 30 - 50 hours use per year will cover quite a large proportion of moboers.
So 400 hours on a 12 year old boat is there or thereabouts.
At that age, condition, engine service record etc. will have quite a bearing on value. Bayliners of a certain age have a bit of a repuitation for dodgy build quality though this is not an issue with newer models. I think 1995 may be after the "wilderness years" but it's worth trying to find out.
As with any boat purchase, getting a proper survey done is essential. It will cost you a bit, but may save you being sold a pup.
Good luck
clivew05
27 Apr 2005
Essex UK
I bought my boat last year and she is 1996, and had 485 egine hours whic hI was told was quite good ... but when you think about it and as in an earlier post about 50 hours a year is average ... so 10 years = 500 hours so about the right ball park figure .... also as already stated - make sure you know the service history, and also make sure that they have been serviced in the last year ....
Good Luck
Its_Only_Money
11 Aug 2004
Leicester - boat on Hamble
Hmmm - ask Solitaire, his entire galley unit broke free from the hull once - only in the Solent /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif
Overdraught
20 Dec 2005
Wiltshire
In MBM last month there was an article on engine hours, saying that comparing a boat with 500 hours with 50 hours is like comparing a car with 50 or 500 miles on it! The 'mystery broker' was suggesting that higher hours can be a good thing due to more frequent use and (probably) more regualr maintenance etc.
When I looked I saw boats with less than 100 hours that were in shocking state. Mine had 280 on a 2001 boat and now has 350 a season later. I wouldn't worry if boat in good order with service history.
If it helps my car has done 4500 and clocked up 90 hours doing so.....
Chris_d
15 Jun 2001
Oxfordshire
The best rule is to ignore the hours, go on condition and service history.
With a boat engine it should be serviced every year regardless of hours run, most boat engines never wear out, but they die through lack of attention and corrosion from the inside out.
400hrs means nothing on a boat of that age, think of it like a 10+ year old car with 4000miles that only been used once or twice a year then left outside on the beach in all weathers.
ari
South coast
Unless you are arguing financial armageddon due to the loss of "red diesel" of course, in which case all boats do 200 hours a year absolute minimum! /forums/images/graemlins/grin.gif
I'd agree with the above, 50ish hours a year seems about normal.
alt
24 Oct 2006
Éire
I have a 2001 and I have 475 hours on her. 100 of those hours were put up by me in the past 4 months! I would not let hours judge my decision. High'ish hours mean lots of use which IMO is good on a boat (Nothing worse than an idle boat/engine)
As said above, check for service receipts and boat condition
PCUK
29 Jun 2005
Westleigh, Nr Tiverton, Devon.
My Cummins is 10 years old and has done 1100 hours. Just run-in at this stage I reckon!
Think of a truck engine doing 200,000 miles before needing anything major.
Average of (say) 50mph = 4000 hours.
