Engine Hours Counter
Jonny_H
15 Aug 2006
Liveaboard - following the sun!
www.freewebs.com
I want to fit an engine hours counter on the boat. The wiring etc all seems quite simple (aided by Sailing Today article in June's magazine).
Have found several hour counters (Maplins quite good) that would suit, however I have hole to fill in the console in the cockpit where some redudant switches are being removed. This is next the the rev gauage and oil temp guage so would seem a good place to put the hour counter. But .... none of the counters I can find say whether they are waterproof! Don't want to wire it all up and make a hole to fit it outside and then have to move it inside and end up with an even bigger hole to sort out on my console!
Anyone found a waterproof hour counter /forums/images/graemlins/confused.gif
Jonny
Jonny_H
15 Aug 2006
www.freewebs.com
Thanks - unfortunately postage from this company (being US) is going to be more than the cost of the item ($28 when I contacted them!) - you can get hour counters from CPC for £12 - hoped someone would know if they are waterproof, or if there was a UK source for waterproof ones?
Jonny
jerryat
20 Mar 2004
Nr Plymouth
Why does it need to be waterproof? You don't need to see it from the cockpit I would have thought, so why not site it below? Mine's just inside inside the companionway (tucked behind the bridgedeck return) and has been fine for 3 years to date.
AIDY
19 Jan 2004
Muckle Flugga
www.ybw.com
Agree... mines in the engine bay wired off the alternator..
why not at the chart table easy when you are doing the log ! not as accurate as the alternator but wire it off the light from the fuel guage, thats if you have one at the chart table.
Jonny_H
15 Aug 2006
www.freewebs.com
That was my initial thought (I would site by the battery switches near the engine) - but as I have a gap on the console that I need to cover up (I have removed some redundant switches) I thought it might look better to put the counter there rather than just fill the holes with gel coat which prob won't match.
Its not a definate, and if its a problem (which it looks like it might be) I will site it below and find another solution to the holes in my console!
Blue5
16 Mar 2006
Hampshire and Portugal
A slight thread hi-jack but I am also looking to install an hour counter on my Westerly Kestrel as I do not subscribe to Sailing Today can anybody point to an on-line link or a wiring diagram for the installation of a meter
asj1
2 Jun 2004
Home: North Bucks, Boat: Suffolk Work :central Lon
Re the Tiny Tach.
I hav ejust been on their website - looks fascinating. It appears to have a transducer clamped to the diesel fuel line. Does this transducer actually make a hole in the fuel line?
Otherwise I can't see how it actually works?
It obviously needs to be wired up to the battery in some way, any idea how quickly it would flatten my battery if the boat is left unnatended for a few weeks?
Lastly - I can of course see teh price in $ - but how much do you sell them for?
gandy
24 Aug 2004
Aberdeenshire (quite far from the Solent)
Hi, the Tiny Tach transducer just clamps onto the fuel line, it doesn't make a hole in it. I assume it senses the pressure pulse. We fitted on just recently. The hour counter only counts while the engine's running, not all the time the unit's powered on. With the engine running it displays rpm, and when the engine's stopped it shows hours run.
UK supplier is here, in case Malthouse can't supply.
http://www.tinytachuk.com/
Jonny_H
15 Aug 2006
www.freewebs.com
Out of interest I contacted Siemens VDO to see if their range was waterproof, their response (and dealer info):
N03-110-412 Oceanline International Black Hourmeter 52mm 12/24V .
Please Contact:-
Furneaux Riddall
Alchorne place
Portsmouth
P03 5pa
Tel:- 02392 668621
Although not cheap! VDO
