jimmertek
New Member
Hi guys
Grateful for any advice here as I'm not an expert on engines.
I've got a Bavaria 300 Sport which up until now hasn't been too much bother. We have twin KAD32s. This weekend I checked water filters, checked impellers (by removing impeller cap and re-attaching cap) and replaced a pre-fuel filter. I checked oil levels etc - no issues found. On my next leg (canal use) my port engine alarmed and overheated. I checked the water filter, checked that fresh water was coming through (leaving lid off and starting engine = water everywhere!) and now pretty stumped after that. I've taken the impeller out and re-inserted it, it looks fine. Water filter cage also fine.
There seems to be slightly less air coming from the exhaust at the back of the boat on the engine that is overheating. However I cannot think what has changed which would make a difference. I also checked the air filter (metal can and re-attached it). Again, to no avail.
There is plenty of coolant, in face the coolant level seems higher in the engine which is overheating (does it expand when hot?).
Could this be a case of plastic bag entering the system and preventing enough water coming through to cool it? It overheats pretty quickly once it has cooled, re-starting the engine and even idling the temperature climbs from 40c to 90c in 5 minutes.
Also, the engine which is overheating, when I idle the throttle the oil / engine pressure dial drops back to 35/45 whereas the starboard engine which has no issues hovers on 60.
Grateful for any advice here! Thanks, Jim
