jacksaid
My Engine stopped over the weekend and although it did restart it would only idle. In neutral advancing the throttle does not increase engine revs. Throttle linkage is OK. I first checked for water in the separator and this was clear. I then disconnected the fuel pipe on the output side of the secondary filter. with both manual priming and turning over the engine no fuel was coming out of the pipe. My assumption is therefore that one or both of the filters are clogged. My next step will be to remove the filters.My questions are:
1) Are my assumptions correct and if so
2) Will clogged filters be apparent eg will I see evidence of clogging without sawing them in half?
3) If they are clogged will I need to drain and flush the tank
4) If they are not clogged what next?
Note filters were new in April. Boat is about 1.5 years old with 400 engine hours - it is a Volvo 2030
Thanks in anticipation
