Engine Cooling temperature
garry_
24 Jun 2003
MD. U.S.A
Hi there.
Does any one know what the correct engine cooling temperature is for a
Ford Lehman 135sp Diesel.
Running at full load, 2200 RPM's
dont know specifically for that engine, raw water cooled or fresh water intercooled?
if intercooled it will probably run at the same temp as a vehicle engine. as it happens i put a new water pump on my corsa 2 days ago and so have been keeping an eye on the temp. operating at normal town and country driving it is runing at around 92 - 96 deg C,
stu
colvic
23 Dec 2001
Hants
The engine thermostat has the operating temperature stamped on it.
Yours is quite a large engine and 2200rpm is not a lot so I would be surprised if it was much above 88 Centigrade. BMC?Thornycrofts run at 84.
Phil
