adey
Condensation is warm, moist air hitting a cooler surface. So, either keep all the surfaces the same temperature (which is almost impossible), ventilate the moist air away or dehumidify.
The cheapest is obviously ventilate. Remove the blanket from the engine and that issue will be solved. You only need a tube heater there if it's going to be well below freezing. Dehumidifier in the engine bay will only work if you seal up every air gap and simple ventilation has to be the better answer.
Your garage tools will fair better if you can insulate the garage a bit better (to reduce the temperature difference) and increase the ventilation.
