engine Anodes volvo penta AQAD41D
There might not be any anodes on the engine
I don't have any engine anodes on my Volvo Penta kad32's - but there are of course anodes are on the sterndrives.
If the engine has a sealed coolant system, with a heat exchanger cooled by raw water, the anodes will be in the cooling system, both for the engine cooling and gearbox ((if you have a gearbox, or in the sterndrive if your set up has those).
Quick question on behalf of MBH
Can anyone tell us where we can find the engine anodes on the above engine. Strangely enough its not in the engine manual
Thank you
I can find almost no info on that engine except that it isa200hp 6cylinder engine made from 1993-4.
However below is a diagram of the heat exchanger for an earlier version. The anode is part #7 in the end cover. Later versions may have a differnt heat excahnger which may not have an anode fitted. If it is not mentioned in the owners manual then there probably is not one.
Hi I have the AD41P in our princess and that version doesn't have the annodes I know the are in the end caps on the A and B versions didn't know there is a D version
