hagrid
Last weekend my port rev counter started to have a fit, I used the good old Seatstart and they corrected the problem, the Alt belt was loose, I got under way... The following day I started the engine and the alarm went off, with the battery symbol flashing. I then restarted it a couple of moments later same thing, I was now getting worried.... I then started for the third time and hey presto everything A OK.
A little while later I see my instruments that are running off the port engine have gone off, I then restart the engine and hey presto all is fine again.. what do i need to check?
regards
regards
