AndrewB
"Heavy Weather Sailing" recommendation.
By Peter Bruce, chapter 29 (4th edition) pp293-4.
"Even when in possession of a sensibly sized storm jib it should be remembered that to be effective to windward, sheet leads and the point where the sheet is attached to the foredeck will, at some stage, have needed careful thought and assessment. Ideally, the tack of the storm jib should be taken to a point somewhat aft of the stem fitting to obtain optimum balance between it and the mainsail/trisail. But to achieve this, a properly designed independent forestay, supported by running backstays, will be necessary. A tack pennant is usually advisable to give greater clearance to waves breaking over the foredeck. In addition, sheet leads will need to be positioned further outboard than for larger headsails to give an angle of 12 - 14 deg from the centreline."
In line with this advice, we switched from a close-in sheeting position with a low set sail keeping the clew close to the block, with a raised position sheeting out to the normal genoa track, which gives the required angle. And in my view, it is an improvement.
And, incidentally, I have bent a perfectly good mast by hoisting a storm jib in 45 knots of wind without setting up proper backstays to balance the babystay. This was a conventional masthead rig with straight spreaders.
I know you are an experienced sailor, and accept that what works on one boat can be different on another. But I don't think it would be appropriate to 'vehomently contradict' this advice in all circumstances.
