hanjae
Active Member
I have a pair of VP151's and since running her up this season we have hit a problem. Both engines have Luminition and the Stbd engine after a short while just cuts out. It is electrical. It will restart and run for a short while then just cuts out again. I have checked all the connections and all are ok. Next I had a spare brand new Luminition so fitted that and still the same. The rev counter is running fast, so to test this used the port tacho and that was fine. Could the tacho cause this problem? what else could it be. sitting on a pontoon it will not reproduce the problem it is only when under way!
HELP please I want to play! When we have some summer!
