rogerthebodger
would reiterate, though, no earth connection is required to any part of your system to make these breakers work.
Very Very wrong.
You are correct thast RCD trip when there is a difference in current in the L and N conductors. The only way there can be a differance is a leak through earth and <span style="color:red"> </span> back to the nutral line which MUST be also connected to earth at the supply point (inverter or generator) <span style="color:black"> </span>
If there is no earth connection at the supply there can be no current flow outside the L / N circuit and thus no trip.
In my case there was no earth commection at the generator and therefore no circuit outside the L / N connectors. and the shock was the current through me retirning through the Neutral line thus no differencr in the RCD and no trip.
In my case the current could not have neem a difect short through me as I would not be writing this.
If you can see what I mean even with a RCD in circuit is there is no alternate path outside the RCD L / N no trip. This alternate path is from the appliance to earth and back to the neutral connector via its connection to earth.
INHO using any mains device which can become covered in water as on deck is very dangerous even with an RCD and more so if the neutral of the supply device is not also earthed.
Very Very wrong.
