Slocumotion
Later: just found this 62lb Bison, interesting.
If you're interested -
http://www.ybw.com/forums/showthread.php?364270-Electric-outboard-woes
If you're interested...
...Just make sure you can charge it on board if you go away for a trip.
That was a Bison?
Torqeedo, YES. Just charge everyday via an inverter.
@Nestaway... I had already considered this and had made up a cable. I am waiting a reply from Torqeedo about using it. But you have answered my questions bar one.... What fuse should I use in the cigar plug ?
Also, I understand that the battery has an internal 4amp fuse. I have a stabilised 12v DC/DC converter but it puts out 5.3amps so presumably I can't use it?
OK have just spoken to someone at Torqeedo. My cable works perfectly and am using a 3amp fuse. 4amps in and correct polarity vital!
To those non believers ... I have been using my motor for several days now without recharging with some fairly long trips and the battery is 55% full.![]()
To charge a 12V battery from another 12V battery requires more than a cable...
If you are still considering the bison - I've just taken delivery of a Flover to replace mine,( which packed up) Not been able to get it on the water yet but just unwrapping it and running it in the shed, it's cheese to the bison's chalk (or should that be the other way around?) Everything about it looks and feels superior.Got a link?
If you are still considering the bison - I've just taken delivery of a Flover to replace mine,( which packed up) ...
http://www.floveroutboard.co.uk/
Which model did you get, and what type of craft does it power?
I've got a 2.4m inflatable, flat bottom. I want to get a couple of MPH in an adverse wind/current.
Flover have discontinued the 55, don't know why. I can get a good deal out of them if I review the 45 on my Bavaria forum.I would have gone for the 55 if money were no object.(The Bison was a 55 and it had plenty of "grunt" - until it suddenly had none that is,)
