mjcoon
How should the extra sets behave when beating with the genoa fully diploid?
Aren't genoas usually haploid? (http://www.diffen.com/difference/Diploid_vs_Haploid)
Mike.
If you can give me some details on your boat I can then give you some baselines to work to.
Class
or
LOA
Keel type and draft
Rig type (masthead, fractional, sloop, ketch etc)
Approx weight.
@Javelin
If I can jump in on this with something a bit different?
I've just got a 2008 Dehler 35 - 35ft LOA, 1.95m fin keel (lead bulb), tall fractional rig (P 14.5, I 15, E 4.7, J 4.1), main 42sq.m., standard genoa 33sq.m., only 107%, about 5500kg.
I'm finding it very difficult to control the genoa head, moving cars all the time, and lots of problems backwinding the main. Very fast when you get it right - but that's not often at the moment!
Any thoughts on this rather different rig please?
We race with a very similar rig. In the light we have found the Jib's top leach tell tale to be the most important on the boat. This MUST be flying. If you choke this off you just stop.
Thanks Ed.
You have tell tales actually on the leech do you?
Mike
(Formerly Troubadour)
I'd buy into moving the car forward in really light wind.
You need twist in light winds, the shear is quite pronounced when the wind is light and you need acceleration which twist will give you.
What twist won't give you is speed so the trick is to tighten the leech as you get up to speed.
Hmm, control of the genoa head.
Is it flapping or is it hooked, need a bit more info really ?
How tight are you setting the halyard ? (I presume its on a spar)
Not too bothered about main back winding as long as the jib leech tell tails are ok.
It might not look pretty but its not usually going to stop you, er hmm
Unless;
How tight is your main luff ? you should be able to pinch an inch or more, it certainly should NOT be tight.
If it is, it will pull the camber forwards choking the slot and can lead to back winding.
How much pre-bend is in the mast , er wait, tell me more about what the head is doing and confirm your halyards are JUST pulling the sail up and not tensioning the luff on either sail.
Yes - think you can make them out in this shot.
Much has been mentioned about traveller positions. I have a Westerly Storm, and it has two sets of track on either side. One is out by the toe rail, outside the shrouds. The second set runs the same length inside the shrouds just under the coach roof. I have never used them, should I ?
Yes can see them. Another little job to do then!
That rig does look similar (but posher sails!) Is that the Elan?
Can I see a tweaker on the clew? They come as part of the optional "racing pack" on the Dehler but we don't have that. Ditto Cunningham unfortunately.
without having the car so far forward that the foot is really loose and bunching up against the guard wires (it's a very low cut sail almost on the deck at the tack, has a below deck furler.)
There are three main factors affecting the head of your jib (assuming the sail is cut ok)
1, Forestay sag
2, Halyard tension
2, Sheet car position
You'll have to forgive here if I've got the rig set-up wrong.
I think the spreaders have a fair amount of rake aft so most of your forestay tension is controlled by your cap shroud tension, set against the lowers too control fore and aft bend.
I assume given the spreader rake that the mast is fractional so backstay tension bends the mast rather than tightening the forestay.
### Yes 90% fractional, 2 sets swept spreaders, discontinuous Dyform rigging, backstay has 32:1 adjuster on it.
If the leeward lower is slack up wind in a f3 ish then I think I'd investigate although I'm not sure this will be the cause of your head issue.
### It doesn't seem right, but not fiddled with it as since it's only 1/3 of the height I couldn't see it affecting the headsail and I didn't want to push the bend higher than it is.
I think I'd be inclined to check the capstay static load anyway if you can find a local with a loos guage. ( got a couple here)
### 8mm Dyform - is that in the range of a Loos gauge? They are very tight. No slackening of downwind one when beating. Edit - yes it is in the range of a big expensive Los gauge!
Halyards are there to pull the sails up and keep them there - IT IS NOT used for tensioning the luff.
### Thinking about that!
To tension the luff you use a Cunningham and you only use the Cunningham to de-power to stave off the decision to reef or reduce sail.
So a tight halyard and a cunningham are one and the same thing.
A tight halyard/cunninham will depower the rig by pulling fullness forward and crucially releasing the leach at the top.
This applies to the main and jib.
### I've never seen a jib with a cunningham - is it common?
Given the above is all ok then the car is moved forward for a given sheet tension, hmmm going to be tricky explaining this.
The angle of the sheet from the clew to the car dictates whether it pulls more on the foot or the leech or it's in the middle and pulls both equally.
Sheet tension dictates how much pull is exerted.
So if your angle favours pulling down on the leech but your foot is too rounded you need to back the car aft a little, still keep it favouring leech tension and apply more sheet tension.
### Understood.
Get some insulating tape and mark the sheet at a known position so you can repeat and tune from a known mark.
As Flaming pointed out a bit of foot round is ok especially as the first 5 or 6' of jib does little upwind as the air is so disturbed but it does act as an end plate on the deck.
### I've clearly been too bothered about that.
Weather helm wont be helped if the jib is not powered properly, maybe bringing the mainsheet car well up to windward and releasing a bit of mainsheet tension to give the main a bit more twist will help but at the penalty of reducing the forestay tension the mainsheet applies.
### Yes we do that.
Try (and I don't like it) adding some Cunningham on the main when you get excessive weather helm and see if this helps.
### Rigging a cunningham is on the job list (the sail has the cringle)
Need to go right now will take a look a little later.
