jay
I’ve finally devised a way of getting the correct voltage to my 24v D1L. I’ve also replaced the fuel pump which turned out to be dead. The heater itself was refurbed and guaranteed to be working at the start of the summer but this is the first opportunity I’ve had to actually try and start it up. I’ve bled the fuel system (using the pump connected direct to the 24v supply) and ensured that fuel is being delivered through the line (the fuel comes from a 2nd outlet on the primary filter).
All that remains now is get the actual heater to fire up!! All that happens when I switch on is the fan runs for about 30sec then it cuts out again. I’ve tried this 4 times now – also with the engine running to make sure there was enough umph at the batteries – but to no avail.
Pleeeeese – anybody with any sensible ideas or advise? Before the bl**dy thing goes over the side!
