captainboo
I have just finally and (carefully!) fitted a D2 which I bought some 2 yrs ago from a fellow forumite. I have had it running a couple of times before installing it. It was if I remember an ex BT one that appeared to have hardly been used. It has been installed with decent size cables direct from the battery and now has a seven day timer and ext temp sensor attached. Since finishing the installation about a week ago I have had it running a couple of times and it all worked as advertised.
This morning I started it up by just pressing the Heat button on the 7 day timer (battery isolator off) and after about 20 mins shut it down by doing the same.
About 2 hrs later I did the same but this time nothing happened. After disconnecting/reconnecting power and still not running I looked for fault codes and AF:09 is there. I tried resetting it but it goes to --:-- and then comes straight back. I have tried taking the main connector apart, cleaning it and putting it back together but same code.
I understand what the code means (heater prevented from working due to ADR mode activated) but there is nothing connected to the pins 13/14 for the ADR mode, but it appears to think it is in that mode and hence not running. The wires for these pins terminate at the main connector and there are no wires coming out the other side.
The only other electrical thing I did during the time it was switched off for the 2 hours was to briefly press the manual bilge pump switch twice to check its operation. The pump is a Whale supersub 600 permanently connected to the same battery as the heater. I can't believe that this has caused the fault but if it has it is a bit worrying!
Any thoughts anyone?
