V1701
Morning all,
I switched the heater up to full just before going to bed last night (am in the habit of running it on full for 10/15 minutes last thing before switching it off). The roaring from the exhaust went quiet, the heat quickly got less and less so I switched it off straight away. There weren't any error codes on the timer/diagnostic, all appeared normal on there. This morning I checked the air intake was clear, there's plenty of fuel in the tank and plenty of charge in the batteries. When I switched it on it produced quite a lot of white smoke, for about 30 seconds. I think it took a bit longer than normal to get up to temperature, but white smoke aside seems now to be working as it should. I have seen some white smoke before a few times, this has been when I've restarted it when it's only just switched itself off on the timer, concluded from that that it doesn't like to be restarted just after it's shut down so no longer do that.
Any ideas what could have caused it to shut down and what caused the white smoke on start-up this morning? Should I inspect & clean the gauze, have a look at the glow plug? I don't have any experience of maintenance/servicing with these heaters so any help/advice gratefully received, the boat's going to her new owners early next week & I don't want for them to have problems with anything...
EDIT: It's just died again, after 50 minutes running, in a puff of white smoke, exhaust noise gone, pump not pumping, help!
