Eberspacher D1l - Heating & Ventilating
stevd
29 Mar 2012
North Wales
Hello,
I am still having issues with my eber D1L
I am sure I am having issues because it is fitted with a timer and thermostat / rheostat as well as being able to ventilate.
When I turn the control switch to ventilate the Eberspacher does just that and the blower powers up. When I change it to heat, nothing happens.
I have been going through the manual, and looking at the wiring diagram, it mentions the you need to disconnect connector when heater required for ventilating purposes.
This is a connector which looks like it goes to connector number 1 & 3 on the switch.
Currently I have nothing connected to number 1 on the switch.
This is driving me crazy.
Does anyone know how or have a simple wiring diagram that shows how the eberspacher should be wired with just the main switch, no other control units, just to see if I can get the thing to fire up.
Here is a link to the PDF that I have been using. The wiring Diagram is on Page 12 and the key is on page 11.
http://www.club80-90.co.uk/pages/downloads/tech/eberB1LD1L.pdf
Many thanks
Steve
No link, but I have the full workshop manual in PDF, it has about half a dozed schematics of varying control configurations, PM me an email address and I will send a copy.
You can use the simplest way to start any eberspacher without going through a switch ,timer or thermostat.
Just remove the connector which takes the leads to the switch and connect the red lead to the yellow ( trigger) lead The heater should start but you will not be able to use the thermostat settings.
Perfect. So that in theory will bypass all of the other 'mess' of re-wiring that has previously taken place. I will try jumping the two tomorrow.
