stav
Hi All,
Happy New Year.
Sorry for this posting but have made a start and was wondering if I can go further?
I am not sure what eber is fitted but it is a water based unit: DL4 or DL5? from early 2000, But can have a look tomorrow.
It ran a month ago but now refuses to start.
I have just a basic control/timer and when pressing the on button there is a little noise from the unit but then nothing, no clicks whires or anything.
I have tried swaping the relay.
The charger was on and the +V showed 13V.
I have taken out each fuse and given it a clean and put back.
I also disconnected the OV wire to see if it would reset itself.
Still nothing so not sure where to go next with it.
There are two thermostats and two heater matrices and the hot water cylinder. The hot water cylinder had had the immersion heater on for a week before trying to start it as forgot to switch it off.
From reading other posts it seems it might be time to take it apart and replace the glow plug? But really any advice on how to move forward would be helpful. Inviting an engineer to look at it is not an option the boat fund simply does not go that far. I have been sailing in some moderate weather and was wondering if water could have gotten in to the exhaust, but is that an exhaust drain shown in the photo? Also despite its age the unit has only run a max of 300 hours as when I bought it the system did not work and very helpful engineer got it running in Brighton and at the time I think he said it had only done 240 hours.
Any helpful thoughts would be really appreciated and comments about scrap value will be expected.
Thanks in advance.
Happy New Year.
Thanks in advance.
