Koeketiene
If you go to Options, top left you can download offline version....it's a zip file, so if your computer doesn't automatically unzip, you'll need to download some freebie software to unzip it for you. It's a flash file on your computer though.
If you don't have flash, then you can choose the print option, and send to a pdf print utility such as pdf995, then choose pdf995 as the printer, and it will send the print spool to the utility, which will create a pdf file on your computer
http://www.pdf995.com/download.html you need to download and install the convertor on the same site as well
It depends on why you want a pdf file?
Brendan,
Thank you for this advice, not doubt given with the best of intentions, however...
The Yudu download is an .exe file.
I'm on a work laptop most of the time. Security is set pretty tight, and I can't run any pre-approved .exe files on it.
Can hardly ask for your mag to be 'approved' as essential to my job![]()
This also means that I can not install any kind of pdf converter program on it!
The reason I would like the mag to be available as a prf file (or Word doc, or whatever) is so that I would be able to download it, keep it and refer to it later without having to be on-line.
