Leonidas
My boat has a dedicated sea earth plate onto which the shore power is earthed. The shore power circuit is protected with RCD and each socket with own fuse. There is no direct connection to the negative of the DC circuits. Is there some reason why the generator could not be earthed to a dedicated sea earth and keep things simple?? Obviously there should be a breaker between the generator and shore power as for these two sources of power to run in parallel they will need to be in phase and synchronized, which I do not believe this facility is available in this generator. Anyway, the recommended procedure is to disconnect the shore power before bringing the generator in line.
