contessaman
The Centaur ( late light models especially ) behaves quite well in the hands of a decent sailor who knows about sail trim.
They only got a reputation as motor sailors because they had 23hp Volvo's, this was simply because Westerlys were offered a good deal by Volvo !
The Centaur may not have the looks of a Contessa but I've been in a F8 in one and she did us proud.
seajet, perhaps instantaneously, we are in agreement.
I crew on a friends centaur quite a lot. wasn't it one of the first to have tank tested bilge keels that produce lift to windward. They sail and look absolutely fine to my eye for what they are. For a while some even had watermota sea-panther 4 cylinder diesels in them. The one I crew on has a 3 cylinder beta in the mid 20 hp range. you could probably get away with 12hp but its not a racing yacht so why not have a bigger engine incase you need it? that way you can punch into a chop or tow another vessel to safety if so required.
my ood34 had a seapanther which was overkill but I notice jeremy fitted it to the contessa 43 (now theres a nice boat) as well. again he probably got a good deal on it - weight saving didnt really matter on the ood when raced as intended. when I craned the seized seapanther from my ood against the harbour wall, the trim was way off without it so she had obviously been designed around the weight of that motor. had I been able to afford to replace it with a light modern diesel the trim would have been off I think- I would have needed ballast.
same probably goes for a centaur if one took the penta out and stuck an outboard on the back.
Biggest sailing let down with the centaur is the roller boom. but its easily enough converted to jiffy reefing on the main. then you can reef her down AND flatten the main. balance the helm with the roller genoa for a tiny bit of weather helm and off you go at a respectable rate. They have bought a lot of fun to a lot of people.
Here's to the OP getting his penta fixed in short order and at modest cost.
