DTDP switch
zoidberg
12 Nov 2016
Rummaging through a drawer hunting for something else, I unearthed this object - picked up when my local Maplins closed some time ago.
Calling PaulDiamond and others. What on earth - or rather, on water - could I reasonably use this for?
Doubt you'll find many uses onboard for a DPDT relay, even if you do, you need to find a suitable base and wire it in, likely more trouble to use than it's worth. DPDT relays with bases can be found on Ebay for under a fiver, with standard spade terminals.
This illustrates the meaning of "don't save by buying." Even if it was reduced, if you didn't need it then the money would have been better saved for a Corneto (or any other random object that would have given you pleasure).
Thanks to those quoting my post and pointing out it's a changeover relay, being an electrician, i never would have worked that out. :)
I also said "not many uses" not "totally useless on a boat" I think in the last 5 years i might have fitted 2.
The one in the OP is rather unusual for a boat. A standard automotive style relay holder, with integrated mounting lug and fuse holder is about £3 and the relays, which use standard spade terminals, are about £4 from 12V planet, even cheaper on Ebay.
I use one in place of the DPDT switch that came with the NASA combined tricolour/anchor light.
I couldn't bring myself to spoil the aesthetics of the lovely existing Moody switch panel.
The tricolour light switch does exactly what it always has done.
The anchor light switch now energises the relay and reverses the current to the masthead unit therefore switching it to all round white.
I know that it's probably using about 75 mA when energised, but for the occasional few nights at anchor it was worth it not to have to change how the switch panel looks (and overall it will still use less power than the previous incandescent 25W bulb did).
Thinking of Martin_J's reply ( thanks ) could I use that on a combined steaming~deck floodlight lamp to be be mast-mounted?
That's a good use of one Martin.
