Gludy
Having recently read up a fair bit on boat handling in rough seas I am finding some confusing advice and I have a number of questions:-
According to Dag Pike in his book Power Boats in Rough Seas, planing boats rely on their speed for stability when slowed down because of rough weather are reasonably unstable and in a following sea the stern can be caught, the boat turn on its bow and broach.
According to a number of sources the problem with the other extreme – displacement boats, whilst more stable at displacement speeds, is that, they are slow and so can easily be caught by a following sea and guess what – the same problem, the stern can lift, rotate about the hull and broach!
Based on this advice I am not sure what the case is should you have the power with an SD hull to travel at high speeds and hence avoid the sea? The advice seems to be that such a boat in a head sea is very good but the reverse is true in a following sea ….. but is this based on the assumption that the speed is not there.? I do not know.
A planning hull with a following sea normally has enough speed to avoid the sea passing it but this ceases to be the case as the seas build up and the boat is forced off the plane. So I guess that if it is not planning then the D hull would be better and maybe the SD hull would still be able to maintain a higher speed through the waves. Again I do not know.
I am not repeating other threads here, I am stating what others say because some of it clashes and is therefore confusing.... in particular I am leading to my questions on drogues.......
Enter the drogue (not sea anchor or parachute) – this is towed behind a boat under power and helps prevent the stern turning and so helps prevent a possible broaching situation. Apparently it will only shave a knot or two off your speed. How many of you out there have a drogue? How many have ever used one? What is your experience of them? It seems that they can be fairly small 20 inches for a 20 foot boat, 30 inches for a 50 foot boat and about 35 inches for a 60 foot boat .. so they are not expensive. They could, it seems (and sorry for this) save your bacon if you are caught below 'escape speed' in a following sea. Yet I do not know a single person with one.
