seaesta
My drive shaft does not seem to run quite true - it has been like this for 15 years and has not (touch wood) been a problem presumably because the flex coupling can cope. The shaft is solid 316 stainless and is connected to the engine via a flex coupling and out through a standard stern gland with grease pipe/nipple and a relatively long stainless tube. The engine runs slowly (old MD1).
I am planning to replace the engine with a Beta which will run up to 3600 rpm and even when reduced through the gear box the shaft is likely to be running much faster than at present. How do I check that the shaft is true and if not how can I get it straightened.
Advice greatly appreciated
Martin
Martin
