Drinking water from the water tank
Gullsea
27 Apr 2014
Hi all,
I am a Dutch newbie on this forum, but I’m kicking off with my burning question straight away… :eek:
This summer I'm going to hit the water for a few weeks with my "new" boat with 150 litre water tank, and I really afraid I will get sick on board due to drinking contaminated water. Does anyone here feel the same, and if so, what do you do to prevent this:confused:
In the Dutch (motor)boating scene people are usually pretty easygoing when it comes to the safety of water on board (for drinking, showering, cleaning, etc..) Well, I am certainly not a coward, but prevention is better than cure ... I am curious what your opinion is when it comes to using filters (membrane / carbon / UV / etc) and adding chemicals to the fresh water tank...
Thanks in advance for your reply! :encouragement:
NoviceRod
1 Mar 2010
Torquay
We use cheapest supermarket bottled water for drinking on the boat. Tank water for everything else.
Of course, it is usual practice to drink other than water when on a boat, I believe;)
prv
29 Nov 2009
Southampton
There was a thread recently on the nearby sailing forum. Can't see any difference between motor and sail on this subject :)
http://www.ybw.com/forums/showthread.php?392920-Do-you-drink-the-water-from-your-tank
A mixture of people who drink only bottled water, people who drink tank water after filtering, and people who keep the tank clean and drink the water directly.
I fall into the latter group, and have never had any problem. The water tastes exactly the same as from my tap at home. I do sterilise the tank with puriclean each spring.
sailorman
21 May 2003
Here or thertemp ashore
Hi all,
we always use the tank & over the winter that water could be weeks old
Robg71
24 Jun 2012
Yorkshire/Aberdeen/Jersey
Once every six months, i do the same to my boat as we do to the fresh water supplies at work, and that is to superchlorinate.
Add a large dose of (basically granulated bleach) to your water tank. Pump it in to your taps, so you can smell it. Leave to stand for six hours, then empty all of it...
Fill with fresh.....
One squeeky clean tank...
BartW
9 Oct 2007
Belgium
www.amptec.be
on the small boats we used to use tablets for cleaning a denture (kunstgebit) for rinsing ones a year the water tank,
on the bigger boat, we make sure that the tank is emptyed and filled very regulary, and use the water for everything except for drinking we use bottled water.
rafiki_
19 Jan 2009
Stratford on Avon
We use the tank for tea and coffee. You can tell when it inserted to be changed, as the taste becomes metallic. For drinking water we use bottled water. I guess if you instal a filter you could use the tank water for drinking?
Bandit
30 Jun 2004
Guernsey
I tend to fully empty the tank at the start of the season and refill with fresh water adding a suitable dose of Aquasol liquid which I believe is chlorine based.
When we are on holiday on the boat after the first tank or so I don't dose it till after the holiday ( wife says it makes the tea taste funny?).
We tend to drink bottled water from the supermarket and we have a 10 litre can we fill from the tap directly for tea and cooking.
I assume in Holland you have to drain the fresh water tank in case of freezing anyway in the winter?
I did once take the inspection hatch off an old boat's water tank once and there were some strange things growing in it?
Be Safe drink beer, wine or spirits
Actionmat
13 Dec 2012
Teddington
We drink the water from the tap, never buy bottled and to be quite honest I think tea tastes better on the boat. I've never put chemicals in the tank, I just use it regularly and empty it before filling up.
superheat6k
10 Jan 2012
South Coast
+1. Simply and regularly empty the tank and refill with fresh, and allow the hose to flush through thoroughly before putting it into the tank.
And please please please don't get the forum going on the subject of marina hoses and the deadly pathogens these can harbour !
Gullsea
27 Apr 2014
So you're doing everything with it except drinking the tank water. I'll probably go for bottled water too when it comes to drinking, although I'm still considering buying a filter and/or a UV purification solution. What I conclude is that if you regularly use and refill the water tank, the water stays 'safe'. I you let it stagnate or just don't use it very often, it can become 'unsafe'.
BTW: Thanks everyone for the response :encouragement: You have been very helpful.
BartW
9 Oct 2007
Belgium
www.amptec.be
yes we use water from the tank for cooking, tea, coffee,... teeth brushing, etc,
I sometimes drink it, but advise guests not to, don't want to spoil there holliday with a bad stomach
some folks prefer to drink bottled water anyway, also at home...
I don't bother with extra filters, etc... its more headache to keep these 100% clean then having bottled water onboard.
we have a desalinator which we don't use a lot, its a headache to keep that clean and rinsed regularly.
Croc
6 Oct 2010
Interesting....about ten years ago i was Commodore of a yacht club with a marina. We heard all about the pathogens in hoses and the committee lead by me had all the hoses on the pontoons removed telling marina users to use their own hoses. A big wail went up from the berth holders but we held firm.
What a mistake... well intentioned but a mistake.
My successor caved in immediately and the hoses were returned (not the same hoses but new ones.)
A few years later I bought a motor cruiser and appreciated the value of pontoon hoses and how much hassle is caused by not having them.So nowadays I keep the boat tanks filled from the hoses and we use the water for washing up, showering and general cleaning. However ,despite putting two Milton tablets into the tank with every fill, we use bottled water for drinking.... and teeth cleaning although a few times after a heavy night I have forgotten to use the bottled water and scrubbed the molars with stuff from the taps with no ill effects.
maby
12 Jun 2009
If you are not confident of the boat's history, give the tanks a good clean out with Puriclean. We then add Aqua Sol on each fill.
On our first boat, the tanks were leaking, so we removed them to replace them - we were horrified at the black sludge in the bottom. We find that the Aqua Sol does not add too much flavour to the water - certainly not noticeable when making hot drinks. We do carry a Brita filter jug for cold drinking water in the summer months.
D
Deleted User YDKXO
Guest
FWIW I've drunk water from the water tank on our boats for years, except in those areas where I've been specifically warned not to (eg N Mallorca) and never had a problem. For a start, every time you brush your teeth using tank water you are 'contaminating' yourself. If you're worried you could drop a couple of purifying tablets in the tank. IMHO scaremongering over mains water just leads to making manufacturers of fancy bottled water even richer and they don't deserve it
C08
8 Feb 2013
We have two Plastimo Flexible tanks and use the tank water without any reservation. We just use a Whale Filter in the line which improves the taste and is claimed to reduce bacteria and solids. The only problem we have with boat water is the S Coast water is not the same quality as in the N England.
