MystyBlue2
Anyhow, To the Op,
It very much can be done 100%
As stainless is expensive and solid especially, I can understand if your nervous incase you ruin it. BUT
Dont be put off. This is not rocket science. It is literally 2x 4mm holes.
Take your time, use plenty of lube, say every 5 seconds of drilling and re oil the bit and the steel and restart. Use a very slow drill speed and use sharp bit fit for purpose. The trick is to keep the speed of the drill to a absolute minimum as if you heat it up too much it will "harden" the steel and blunt your bits.
If you decide to take it to a company then fair play but you CAN do this yourself. If you choose to do it yourself send me a PM and il help as much as i can.
