MainlySteam
Have decided it is about time I should replace the coolant in our MD22L engine for the first time (yes it has taken me a long time to get around to this!).
In the user manual it refers to a drain "plug on the right hand side of the engine block". However, on our engine there is no plug, but is instead a hexagonal fitting with a nipple at one end that is screwed into the block and into the other end of the fitting is screwed a hosetail.
Now I assume that this works like the arrangement such as for bleeding brakes on cars, ie just loosen the nipple and the coolant will run out through a piece of hose which one has had the forethought to slip onto the hosetail. However, to save me experimenting and maybe ending up with a handful of fittings, a bilge full of coolant and a distraught look on my face, is anyone familiar with this arrangement and able to confirm my suspicions are correct? One reason I ask is that the hosetail looks just like a plain ordinary hosetail, but there is obviously something inside either the hexagonal fitting or the hosetail which ordinarily blocks the coolant from flowing through them.
John
John
