geem
Maybe we should have a collection and by him a decent anchor. If he is so vocal about the virtues of a CQR imagine how vocal he would be about an anchor that actually worked.....
is that based on your experience of using a modern anchor?
JD is obviously very bored, has it been raining a lot in the UK?. Maybe someone can start another thread that might divert his attention.
How about, Black is the new White?
Jonathan
What did you expect? Starting an anchor thread.![]()
The thread was focussed at the experience(s) of people who had had pre-modern anchors and have used a, or some, modern styles. It was a thread trying to define if these modern anchors had any weaknesses, did they drag, how and when.
What, then, is the relevance of the anchor they used before? Has hearing of dragging problems with modern anchors modified your views at all?
well caught sir!
Vyv the float in you picture like frequently seen in Noelex's underwater pics, why? Is this an Eastern Med anchor marking habit or one that passed me by over the years that I should adopt? In some of Noelex's interesting pics It looked like a line wrap could potentially have hindered a set or a reset.
I doubt that the lines used could adversely affect anchoring. We adopted a line and float after a swivel failure when we were unable to find the anchor. Since then we find it very useful to locate the anchor when diving on it, particularly in weed but even when buried in sand. It is very common in eastern Med: I understand that all Sunsail boats have them. In extremis I could probably pull a wedged anchor out using it.
well caught sir!
An underwater float is not often seen outside Europe, but I think it is a good idea that could be usefully be used elsewhere.
The main advantage is that if you snorkel to check the anchor it is easier to find.
Thanks Noelex, I will make me one up and short enough to clear the prop under all normal circumstances. We only have 5ft draught these days but sail and cruise in very 'skinny' waters, in Septic parlance I have yet find out if I can snorkel still after my stroke 3 years back, haven't tried it yet although it would probably be OK and verygood exercise. My lovely mermaid never was good at it. .
It is especially useful for anchors without a roll bar which disappear as soon as the fluke and shank are buried. A roll bar works as a permanent float but in soft substrates, or strong wind, even a tall roll bar can disappear. In thick weed any anchor can be very hard to find even when poorly set.
The other big advantage of an underwater float is that it is much easier if you need to to attach a line to pull a stuck anchor out backwards. Diving and threading a rope though a small hole is not easy. Especially if the hole is buried. The float reduces the need to dive by a couple of metres which is a help when holding your breath.
There is some risk the float can get caught under the anchor. This is rare, and will not have much effect, but is less than ideal.
If anchoring in very shallow water where there is a risk of catching the float in props you need to use a cable tie to shorten the rope, but it needs to be very shallow water before this a problem.
This shows the underwater float in action on my Mantus anchor:
Here is one of the rare occasions when my float has caught under the fluke:
If you are cruising in areas where it is practical to snorkel, or dive an underwater float is worth considering.
It has no relevance at all, I'm not sure why you ask - it is not requested in the opening post.
You have missed your vocation - anchor salesman.
One thing i have definitely learnt is that you have no interest in people sharing their views on modern anchors and would rather they did not, share.
Thanks Noelex I will make something suitable up. These days we cruise in very 'skinny ' waters to use Septic parlance so it could be useful but needs to be fairly short. I have not snorkeled or even swum in the ocean since recovering from a stroke 3 years ago but it would probably be very good exercise even if I could not reach a loop in the float line with our extendable boathook either from the RIB or from on deck. I guess the line doesn't need to be too thick maybe 4 or 5mm. and I think I have something suitable.
