Neeves
Many of us have owned both old style anchors, CQR, Bruce and Delta, and have invested in more modern interpretations, Rocna, Vulcan, Knox, Excel, SARCA, Mantus, Spade - sorry if I missed any. I'm not sure where to place Fortress, its performance when used appropriately makes it modern, its inception was over 25 years ago. (but then so are Spade and SARCA)
Those that have invested in the more modern versions did so, not out of desire to support an anchor maker, but to reduce or remove the incidence of dragging. People wanted certainty, or greater certainty.
I wondered if owners of these modern versions might like to comment on whether their aspirations have been met - have the new designs reduced the risk of dragging or have they actually removed dragging completely.
To minimise any thread drift to, 'my modern anchor is better than any other modern anchor', there is no need to mention design or model - just that you have a modern anchor (weight would be interesting) and it has never dragged (compared with 3 times a year with the old model of weight 'Y' - no need to mention make) and its used on a yacht, of whatever length, interesting to quote length.
If you have dragged with a modern anchor - there might be mitigating circumstances - which you might like to describe.
We used to drag regularly with a brand name articulated plough, oddly we would drag under the most benign conditions and equally oddly it would hold in conditions when we thought it would definitely drag. It weighed in at around 20kg and we used it on our 38' cat. We use lots of different anchors but regularly use one specific 15kg model (we have tested most of the models, around 15kgs, mentioned, and some more). We have dragged 2 times, once it caught something in the toe and dragged with winds of 30 knots and second time we were anchored in thin slime (mud) in a river and dragged slowly in 55 knots, the anchor seemed to 'hold' in that we did not accelerate but did move aft in a controlled manner. Having moved 20m and into shallower water the anchor suddenly locked up and we did not move further, I assume the anchor found a firmer substrate. In both cases we had plenty of chain deployed, 8mm - scope was not an issue.
I do not see how we could have anticipated catching something in the toe, just bad luck. Few anchors work in thin slime/mud - now we would use a fluke anchor as they seem the only reliable option.
Anticipating the results, I expect modern designs to enjoy wholehearted support - but wonder how much is due to people moving up in size and wondering if modern anchors have any weaknesses. Are they infallible?
Jonathan
Jonathan
