Down wind sails
Yacht Breeze
7 Jan 2012
We have a Bavaria 40. It has a furling headsail and in-mast furling main. I would like to add a down wind sail. There's usually just the two of us on board so ease of handling is important. Has anyone else got a 40 footer, sailed by husband and wife and discovered the perfect down-wind sail?
pissativlypossed
20 Jan 2004
West Midlands & Plymouth
Good question, same applies to us, boat is a Jeanneau 42 ds. Help us please!
Little Five
16 Aug 2010
glasgow
Be sure to specify to the sailmaker that you wish to use the sail for downwind sailing as some cuts of cruising chutes will not set for dead downwind sailing.
ianat182
10 Jul 2008
,home Portchester
As these sails are quite costly,plus snuffer gear, perhaps a secondhand sail may be the way to go. I've just seen Yacht Exchange sails company on the web (01752 895004) who have new and good used sails to sell/buy; the sails are graded from 1-10 for condition from brand new etc. so may be worth a query.
You will need to know the luff length from the halyard exit to the bow roller position, less 2-3 ft, to allow for the tack line or strop length to be added when fitted; I do not know whether this measurement is altered when a snuffer or furler is used though, as I prefer less ropes to handle, and do not use them.
Two-handed on both boat types should not be a problem; previous posts of mine and others describe the setting up and dowsing methods employed; but probably F2-3 would be the maximum to be handled without too much worry.
ianat182
LadyInBed
2 Sep 2001
Me - Zumerzet Boat - Wareham
montymariner.co.uk
This is my short handed down wind rig
Neil_Y
28 Oct 2004
Devon
www.h4marine.com
40' Bav two of us most of the time, a No1 and No2 Genoa on the furler and no main, we had a huge kite as well which sometimes came out when we got bored.
It looked like this (this is mid atlantic 800 miles W of Azores ish)
Ludd
3 Feb 2009
Las Palmas, Gran Canaria
As an addendum to my poled out genny and cruising chute post,I should have said I set the main boom to the cruising chute side,prevented, and run the cc sheet through a snatch block on the end of it.
Neil_Y
28 Oct 2004
Devon
www.h4marine.com
In answer to Ken, dead astern we were overtaken by the Dutch yacht "Heavy lady" Bob and Kate. Actually we saw them in the distance and then slowed down, I'd just unrolled full sail to come up beside them when this picture was taken. It was quite weird and then we met up again in the Azores and Spain on our way back.
This was perfect ocean sailing! great memories.
flaming
24 Mar 2004
The replies so far have focussed on Ocean sailing, and I'd be hard pushed to argue with them for medium - heavy airs tradewind sailing.
If however you were thinking more along the lines of light wind summer coastal sailing, then I'd actually suggest a spinnaker....
The reason I'd suggest a spinnaker instead of a cruising chute is the ability to go downwind by pulling the pole back, coupled with the ability to reach with the pole forward make it more useful over a wider wind range. It's also much more stable when going downwind. True you can set a cruising chute as a spinnaker by poling the tack back - but if you're choosing from scratch why settle for a compromise?
Most cruising couples I've ever met don't go throwing 20 gybes in with the coloured sails up, but set it with 10 miles to go in a straight line and a steady wind. Under those conditions a spinnaker is no problem to handle, and will boost speed in light winds to the point at which you won't have to resort to the engine.
temptress
15 Aug 2002
Gone Sailing -in Greece for a while
gbr195t.com
The reason I'd suggest a spinnaker instead of a cruising chute is the ability to go downwind by pulling the pole back, coupled with the ability to reach with th.....
We mostly sail Temptress (47ft) 2 up, Just SWMBO and I. In strong winds we set a poled out head-sail but in f5 or below we use a Spinnaker ( we carry 2 of these - A heavy 1.5oz and a lighter 0.75 oz), we also use an Aysemetric spinnaker- (not a cruising chute) when the wind is forward somewhat. All of these are on Snuffers.
Snufflers once you learn how to use them they are great. To gybe we pull the snufflr down, gybe the main and set the kite up on the other gybe then pull the snuffer. We hardly ever gybe the Asymmetric.
