Domestic battery bank.
Vara
20 Feb 2004
Canterbury/Dover
My designed set up is for 3x 85ah.
I'm thinking of replacing with one 225ah.
Apart from a small drop in capacity what are the pitfalls of just having one battery.
(engine start is separate)
VicMallows
25 Nov 2003
Emsworth, Chichester Hbr, UK
The obvious disadvantage is the sheer weight.
Cost? 85Ahr batteries are produced in vast quantities for the caravan market
and are usually the most cost effective in terms of £ per AHr.
You must have some reason for thinking of going that route ? .... maybe an available source of 225 AHr batteries ;)
Vic
Ammonite
7 Feb 2007
Not sure I understand the replies so far..
I thought 3 x 85ah would roughly the same as 1 x 225ah i.e. about 60kg
He's not planning on installing 3 x 225ah unless I've read the post wrong
Agree with the point about cost though with 85ah being around £70 and a Vetus 225ah being around £550
sailorman
21 May 2003
Here or thertemp ashore
do you lift all 3 85Ah at the same time :cool:
with 3 in one goes like Homers beer ( Duff) you can isolate it & carry on
Ammonite
7 Feb 2007
I see what you mean about weight now, although for £500 I'd expect the bloke who sold it to fit it :) Mind you I'm sure two people could manage 60kg between them every 5 years or so (or could find someone who could)
Cost and safety factor of having 3 batteries much more important in my view
jordanbasset
31 Dec 2007
UK, sometimes Greece and Spain
We have 4 x 140 ah, speaking for myself I would not want to carry around anything much bigger than those. Perhaps 2 x110ah would be another option. But as some one else has said I would look at cost per ah of the batteries availlable
pappaecho
13 Oct 2004
S. Hampshire
Most 85 amp hour batteries last for a number of years, but some will give up the ghost before others. If you buy a single 225 mp lump and one cell goes after a few years you are chucking away £550. If one 85 amp hour battery loses a cell you are only chucking away £70.
In 2004, whilst doing up a boat I found a 75 amp hour battery by the marina skip. It had been thrown away. It was charged up and worked Ok, and is still starting the engine 7 years later. No idea of how old it is!
noelex
2 Jul 2005
The most cost effective deep cycle batteries tend to be the 6v ones so I would look to see if 2x 6v 200Ahr batteries would suit. This also solves the weight problem, although if my wife and I can manage 12v 200Ahr batteries (3 of them) from shore into the dingy and on to the boat then most couples should not have too many problems.
NormanS
10 Nov 2008
It's just that this caught my eye;
http://www.alpha-batteries.co.uk/bu...-calcium-225amp-leisure-battery/prod_101.html
The weight isn't a problem.
Would simplify wiring and would only require minor surgery to battery storage area.
That is an amazing price. I have 3 x 170amp similar batteries, which, earlier this year, cost a lot more than this company's quoted £139. :mad:
We managed the 170amp batteries by dinghy, and into place, but I wouldn't have liked to have tried that with the even bigger and heavier 225 ones
PetiteFleur
29 Feb 2008
Suffolk
I've also got 2 x 105ah batteries from Battery Megastore, good price which includes next day delivery. Replaced 2 x lorry 110ah batteries which only lasted about 3 years.
