Domestic batteries pancaked!
mireland
26 Apr 2004
Thames valley, UK
Visited the boat today to see that all was well and it wasn't! Domestics so flat the NASA monitor not even showing its display!! Batteries new last July. Anyone suggest a reasonable electrician in Cardiff area to diagnose problem? Thanks a lot.
Allan
17 Mar 2004
Lymington
Where do you keep your boat? Was the main switch turned off? If so, do you have anything, like a bilge pump, connected before the main switch?
Allan
mireland
26 Apr 2004
Thames valley, UK
Allan
Boat in Cardiff Bay. Have engaged an electrician now to come and diagnose for me. Left the boat as I always do with main switch off. There is no bilge pump before the main switch. All a bit baffling. Thanks for the reply.
graham
Hope you get it sorted out.
There used to be a good place for leisure batteries on the roundabout by the Heath entry to the Heath Hospital. Havent been there for years, maybe someone else can confirm they are still there?
rafiki_
19 Jan 2009
Stratford on Avon
Sorry to be a doom monger, but these things are very difficult to diagnose, unless there is a really obvious current draw. Better news is that given your batts are 6 months old, then they should recover with a decent charge. If there is sufficient bilge pump activity to drain all the batts, then this would indicate a serious ingress problem, which will be quite obvious to spot.
Good luck
DAVIDO
25 Aug 2006
Cardiff
Still there (Garwoods) bought a battery for the bow thruster a couple of months ago.
mireland
26 Apr 2004
Thames valley, UK
Electrician came and it seems it may be the battery monitor that is to blame. The batteries are most certainly drained but when we ran the engine and put enough charge in to run the saloon lights etc the display on the monitor was still absent. The backlight came on alright but no magic numbers and voltages!! Electrician thinks it may well be the monitor that sprang a fault and drained the batteries. Now taken the monitor out and we will see what happens.
Allan
17 Mar 2004
Lymington
That's interesting. I will keep a lookout on my NASA unit. What do you have on board to keep the batteries up?
Allan
mireland
26 Apr 2004
Thames valley, UK
Allan
I have an aerogen 100 for use on passage but as I have no regulator I tie it up when I am away from the boat for fear of boiling the batteries. I can't find a regulator at a price I can afford!
