Ric
There is a french bloke sailing an IMOCA 60 around the world at the moment in the Vendee Globe properly single-handed (he has only one hand) and he is managing ok.
Duncan West's method for singlehanded or short handed, which I have used singlehanded, is to drop a folding dinghy anchor on a warp through the loop and jog it to open and pull the warp via the mid ship cleat. I have also moored on a Baltic type with twin piles. My method is to get only the windward pile and gently motor the boat orward until you can go forward to fix the bow and then move back and allow the wind to move the stern over to the other pile to fix the other line, finally adjust your position. Also possible to do it in reverse and you can usually loop both posts.Lovely.
And where does he show you how that works on the French and Dutch minimal buoyancy fingers that are a measly 3m long and have that natty loop for tying off at the end? Or the Baltic model, where you are expected to lasso two pilings en passent, while backing in with a forty knot cross wind and a long keel?
He is very skilled at sailing with his disability, but this type of sailing avoids frequent berthing problems.There is a french bloke sailing an IMOCA 60 around the world at the moment in the Vendee Globe properly single-handed (he has only one hand) and he is managing ok.
Page 83 of his book:Lovely.
At sea a bigger boat is easier & the platform is better as it is more stable. i sail a 31 ft boat & cover almost 2000 miles PA ( in non covid times) I nearly bought a 37 ft boat 2 years ago but decided that i was not fit enough & do not have the strength. I have done over 300 lock passages, 75% SH & in a 31 ft boat less than 8 have ever gone wrong. I have transited following 2 of my friends in their 40ft boat & when they get it wrong they really struggle with the weight & that is for 2 of them.great Video! well in the short term I will be sailing Bristol Channel, West Coast, Eire and Scotland. Weekenders to Tenby, longer holidays to I hope Scilly or even Scotland. Post retirement, (6 years I hope) everywhere and anywhere. Definitely Baltic and Med then across the pond and beyond. I intend to have crew and company but don’t want this to be a dependency for use in any way. Budget is a tough one all being well I hope to be able to spend 50-100 but I’m not quite sure which end I’ll be at. An old friend who retired ahead of me got an Oyster 406DS to do the big trip but he had deeper pockets
That ought to work, but it's quite a small jib, so you'd probably need to ease the mainsheet a fair bit to balance the two. There is, of course, only one way to find out, to get out there and look like an idiot for a few minutes while you work it outCan you not heave to in a Hanse by clipping back the self tacker ? Just asking as we have one (self tacker ) but I have never tried it
I think the problem is that you can't get the clew of the jib far enough to weather. My Hunter Channel 31 has a s/t jib and I tie a short line from the clew eyelet to a stanchion base to improve heaving to.Can you not heave to in a Hanse by clipping back the self tacker ? Just asking as we have one (self tacker ) but I have never tried it
Or better still rig a couple of stern fenders and you have a wide flat surface to hold the boat against.I have adopted a simple technique that I first saw a French yachtsman using.
Rig a bow fender.
Motor gently up to the walkway at the end of the catway so that the bow fender is pressed against it.
Leave the engine running slowly.
Put the tiller over towards the catway and hold it there with a loop of shockcord ( I have a loop each side)
The boat will stay put while you step ashore and attach your lines.
Just to be sure, I am talking about heaving too in F8. Not in f4 with someone nudging the helm every few minutes. Lots of owners have tried it & i know of one owner who has deemed it impossible even in his 60ft Hanse. The fin is quite short- as for many AWBs & of course one can lock the ST over. I use haulers for when i am off the wind so I can easily keep the jib to one side. I have tried all variations of mainsail angle & tiller angle without lasting RELIABLE success. On my last 2 boats I could let the main right out & they would partially fillwithout actually flogging ; but on the Hanse the main flogs so much that it would soon ruin my laminate sails.That ought to work, but it's quite a small jib, so you'd probably need to ease the mainsheet a fair bit to balance the two. There is, of course, only one way to find out, to get out there and look like an idiot for a few minutes while you work it out![]()
Do you mean I should reverse my Twister into a marina berth?Or better still rig a couple of stern fenders and you have a wide flat surface to hold the boat against.
I did a short article in our cruising website Stonemoorings.com ( by the way we have moorings available on the river Blackwater Moorings available ) & the article can be found atDuncan West's method for singlehanded or short handed, which I have used singlehanded, is to drop a folding dinghy anchor on a warp through the loop and jog it to open and pull the warp via the mid ship cleat. I have also moored on a Baltic type with twin piles. My method is to get only the windward pile and gently motor the boat orward until you can go forward to fix the bow and then move back and allow the wind to move the stern over to the other pile to fix the other line, finally adjust your position. Also possible to do it in reverse and you can usually loop both posts.
I’d video that anytime - what works for fin keeled wide sterned boat may be more amusing in your case.Do you mean I should reverse my Twister into a marina berth?
