rafiki_
Ok, starting with a modern automotive factory, you will see next to no automation in Trim and Final, where the body is fitted with the powertrain, suspension units, harnesses and the interior. It is not cost effective. You will see lots of automation in the B-I-W assembly, and the paint shop. Lots of highly repetitive activity with little choice of options. Again, not much automation in the engine assembly, but some in the machine shop. How could this translate to boatbuilders? Hardly at all. However, there are lots of opportunities at both Fairline and Sunseeker for significant efficiency improvements. I can talk about Princess, as I’ve never been round their factory. Some basic principles. You only add value to a work piece when you are working on it. All the time there is no work it is wasteful. Obvious really, but how many part built hulls do you see with nothing happening? Either they are in the wrong part of the hall, and need moving, or are awaiting parts to be made in another hall. A modern car assembly line, where complete sub assemblies are sequenced, sees some value add to the car all the time. There should be less than 300 parts assembled in trim and final. Nissan takes 15 hours to assemble a car in Sunderland. This is world class. The suppliers only get paid when the part or sub-assembly is on the car, and the system adds it to the virtual build card. Can this translate to boatbuilding? The principles can, but not the detail. How many car manufacturers make harnesses? None. Actually there is no automation in harness building, they are built on pin boards, in low cost countries. The harnesses for most of UK/EU were built in the Ukraine, until Putins folly. Took 3 weeks to re-source as it is low skilled, with no tooling. How many make seats and soft trim? None.I don't think that's a realistic representation of the process.
Happy to be corrected by someone (rafiki?) much more expert than myself, but I believe that's the time to assemble rather than really "build" the thing.
I mean, AFAIK most if not all the more complex components are built elsewhere (often by different companies!) and brought to the final assembly line ready to be screwed together.
