Does anyone use a SCS Pactor modem and Furuno SSB.
mocruising
21 Mar 2004
TURKEY
I have to make up some cables to connect my Furuno 1550 SSB to the as yet unpurchased PTC-II USB modem, any one done it before.
No, but I did make my own cables to connect a Pactor IIex to my Icom 802. It was very simple as it was a 8pin Din - 8pin Din and a RS232 to RS232 for the remote tuning.
I couldn't be bothered with soldering onto plugs so bought a couple of complete cables and cut them, work out which wire corresponded to which pin (use a multimeter with a 'beep' for low resistance) and then solder the correctly coloured wires together.
The Pactor documentation was very good, and I got the radio reference from the web, so it was easy to know which pins had to be connected, and it was only 5 of the 8 in the DIN and 3 of the 9 in the RS232.
Be careful to work out whether the diagrams are showing the plug or socket as I got my numbering reversed first time round and nothing worked until I realised my error.
Nick
I got Bob Smith (yachtcom.co.uk) to make mine up. He's hot on all this stuff and charges reasonably for the service.
Hi. You can find some reference to connecting Furuno 1503 to PTC2* modems in AirMail Help file. If I remember correctly the 1503 can't operate at 100% duty cycle - it overheats. Maybe the 1550 overcomes that problem...Most of our pactor connections work perfectly well at reduced RF o/p of 20/30W. You could try contacting AirMail author directly regarding 1550 & PTC2-usb - he may well be able to provide all the necessary parameter settings as well as conections. SCS do provide made up cables for many radios as do hfradio.com.
