charles_reed
On the new 130' - that's a real biggie - for serious cruising.
This comes from the website: http://www.setsail.com/?s=Manson+Supreme&x=0&y=0
Paul Shard Says:
July 27th, 2015 at 3:00 am
I see you have upsized from the Rocna 240 on your 83 footer to the larger 350 Manson on your new Dream Machine 78… were there times you felt the 240 was not sufficient? Or any other reason for the switch?
Steve Dashew Reply:
July 28th, 2015 at 5:43 am
Hi Paul: First reason for going bigger is because of additional windage. The second is because this allows even shorter scope.
Bob N Says:
July 27th, 2015 at 9:52 am
Not so much an anchor as a way of life. Why the change to Manson?
Steve Dashew Reply:
July 28th, 2015 at 5:45 am
Howdy Bob: The Manson is locally built (New Zealand) in a Lloyd’s approved shop.
The vessel (130') falls off the Rocna sizing chart so I do not know what they might recommend, vs what was chosen. It falls off the Manson sizing charts but Manson do say this:
NOTE: The Supreme is a Super High Holding Power Anchor, so a size smaller than the Plough may be used - ie 30lb Plough may be replaced with a 25lb Supreme.
The Manson Plough sizing charts is as follows
. Manson Plough 60lb
48' - 55'
Maybe 27kgs, vs 58kg for the Mantus - so instead of downsizing, as Manson suggest, the weight is effectively doubled, or 2.14 to be pedantic
Jonathan
edit - My 2 times was a 'ball park' figure baed on Noelex, Dashew et al actual usage - it was not intended to be spin, exaggeration for impact. close edit.
I've a pretty uninhibited attitude to having an "oversize" anchor. If you can, handle it, have it not destroy your trim and afford it - well why not?
I'd even go along with the inference that it's better to put your weight in the anchor than in the chain - Dashew is one of those who recommends "undersize" high test chain.
I remember one extremely careful and conscientious ex Red Cross project manager I met on my travels who, when he took up sailing, upped the rigging, chain and anchor specs on his boat from the original.
He had a constant leak from the top of the rudder tube as the boat was some 250mm above design-marks. Providing his battery stood up to the constant drain from the bilge pump, he was happy that he was so much safer...
